After adding numerous comments and track-changes corrections on a single page, the balloons at the bottom appear in gray, their titles are overlapped, and are unclickable:
This happens when the “Show in the pane” and “Show” options are enabled, in the Review section.
I’m attaching a sample file to illustrate the problem.
Non-responding area after adding a large number of comments
- Comments problem.docx
- (14.29 KiB) Downloaded 5749 times
raitis.veksejs
Re: Non-responding area after adding a large number of comments
I was able to reproduce the problem and reported it to our developers' team. As soon as there will be some fix or information I'll add post here. As I see this problem happens with the Beta version only, in TextMaker 2021 also last comments can be accessed on the page.
raitis.veksejs
The issue you reported has been resolved and a fix will be delivered to customers with the next SoftMaker Office Beta update.
