data that includes a negative sign on the left
mikeism
Post by mikeism »
When I import financial data that includes a negative sign on the left, even if I designate the column as currency or number format, Planmaker imports the data as text. For example, characters like these... -$1015.00, -$105.57, -$722.43 are imported as text. I tried the Format / Cell options to specify currency and tried number as well but Planmaker failed to convert; still treats the data as text and thus I can't perform math operations. Also tried to cut the data and paste back in as unformated text; that works on text without a minus sign but not on text with a minus sign to the left. What is the process for converting data like this to currncy or number format? Why doesn't PlanMaker convert to number format when you configure the import dialog box to do so?
raitis.veksejs
Re: data that includes a negative sign on the left
Post by raitis.veksejs »
To test your described scenario, we would like to ask you a description of what you do step-by-step and an exact sample file. If it contains sensitive data you can send it us to e-mail forum [at] softmaker.com and include also link to this forum.
It should not display negative values as "-$1015.00" if the cell is set to display numbers as currency. It should display as "($1015.00). Conversely, if the cell is set for "Number," it should not display a dollar sign.
How are you entering the values -- exactly?
mikeism
Post by mikeism »
Hi Woody... I'm not entering these numbers manually. I'm importing them. As far as I can tell, it isn't possible to manually enter numbers in the format I described. To summarize:
-$57.00 fails
$-57.00 is ok
My import file from my bank can't be changed and Planmaker fails to recognize it as number when imported. The VALUE function will not convert it either.
mikeism
Post by mikeism »
As clarification to my prior post...
1) This number: -$57.00 can NOT BE ENTERED MANUALLY. When I try to enter it manually Planmaker displays an error and will not accept it.
2) This number: -$57.00 can NOT BE IMPORTED as a number. Planmaker treats it only as text. Even the VALUE function can't convert it to number or currency format.
$-57.00 is ok. -$57.00 doesn't work.
mikeism wrote: Sat Apr 29, 2023 1:22 am Hi Woody... I'm not entering these numbers manually. I'm importing them. As far as I can tell, it isn't possible to manually enter numbers in the format I described. To summarize:
-$57.00 fails
$-57.00 is ok
Okay, now I understand the problem. I am sorry but I can't offer any solution. SoftMaker's development team is going to have to devise a conversion utility within the program.
Thanks for your post, but we are unable to reproduce this problem, and we are able to use both the formats. Please check the attached file imported from another software.
If you are still getting this problem, please send your file to forum[at]softmaker.com with link of this post.
Negative currency test.xlsx
(6.28 KiB) Downloaded 5159 times
SuperTech wrote: Sun Apr 30, 2023 4:11 pm Thanks for your post, but we are unable to reproduce this problem, and we are able to use both the formats. Please check the attached file imported from another software.
What software was your sample imported from?
I believe the problem Mikeism has encountered is caused by the fact that his source data are formatted as text at the source document, which makes it impossible for PlanMaker to recognize it as monetary values when imported. I just created a sample document consisting of three lines of monetary value, using Notepad. I then imported it into PlanMaker and attempted to add the three values using the SUM function. It failed, and returned a sum equal to zero.
In your sample file, you used a custom number format. I attempted to reproduce a usable function by creating a custom cell format using the same character string as in your sample file. After changing the format of all three of my cells to that format, the total remained displayed as zero not as -$285.00.
See attached:
PlanMaker_Sample.xlsx
(5.84 KiB) Downloaded 5102 times
Notepad_Sample.txt
(26 Bytes) Downloaded 5323 times
@SonCook
Re: imported numeric data that includes a negative sign on the left
Post by @SonCook »
This string is already 2 years old. Has any 'fix' come down from SoftMaker? I, too, have downloaded banking activity from my credit union. It was downloaded in CSV format (no choice allowed). When I go to open that file, I specify that the columns showing a transaction amount and the running balance be identified as numerals but, they are not. I have tried methods discussed above - none of them work. There are several hundred transactions so I am not looking forward to re-entering negative numbers manually. The data from the CU shows as "-500.00". The function "isnumber()" shows "False" whatever I try to use to convert. Any movement on this problem?
Thank you for posting your issue here, but as you can see above the problem was not related to PlanMaker, and we didn't receive the file requested.
Please try following solution of your issue:
  1. Copy the column with these problematic values
  2. Paste it by using right click > Paste special
  3. Select “Unformatted text” in Paste as field > OK
Or you can also try this process:
  1. Just insert a temporary column next to your data
  2. Multiply the column with these problematic values by 1 in that new column, you will get all numbers
  3. Then you can copy and paste that new column as values only
If the issue persists, please send the requested problematic CSV file with steps involved and the screenshot of the issue so that we can check at our end.
