Presentations file exported as MS Office format damaged[bug?]
nadiehimemori
Post by nadiehimemori »
Hello everybody. This is my first post at the forum and as I don't see it around I decide to post it. Every time I use the Presentations program, I got an error while I try to open it using MS PowerPoint, as it shows it's damaged and the information can't be recovered or retrieved. It's not the first time it happens, so I decided to post it here and wait for a solution.
Thanks in regards.
Re: Presentations file exported as MS Office format damaged[bug?]
Thanks for your post. Please share the file in which you are getting this problem so that we can investigate it. Also, please update your SoftMaker Office to the latest revision.
Return to “Presentations 2021 for Windows”
