How to install Textmaker
caspar4
Post by caspar4 »
I have only Planmaker installed from my Softmaker 2021 package.
How can I install Textmaker?
nadiehimemori
Re: How to install Textmaker
Post by nadiehimemori »
When you make the download of the Soft Maker Setup, it got automatically installed with the full programs, this means all the programs should be already installed on your system. You can try to make a search on the Windows bar (if you are using W11 or 10) to confirm it.
Devonboy78
Post by Devonboy78 »
If you run freeoffice21.msi from your software package it should install Textmaker for you
Please start the installation, select custom, after which you will get option to select app which you want to install.
Bjourno
Post by Bjourno »
Isn't TexMaker included HERE..?
