Double-click on backspace = click backspace then delete
mbb
Post by mbb »
If backspace is clicked twice, in a fast pace, the second click behaves like the key "delete". Expected behaviour is two clicks on backspace. Is this intentional, an optional behaviour, a bug?
This is annoying because, for some reason, TextMaker is a bit slow on my machine, so, I have to be careful using backspace or not use it at all. I just checked SMO 2021 doesn't have this behaviour.
Thanks,
Re: Double-click on backspace = click backspace then delete
Thanks for posting your problem, but we are unable to reproduce it. Please make sure, your keyboard is working fine.
If possible, please share a screen recording for better understanding.
mbb
Post by mbb »
This problem is gone on the new build.
It's good to know that your problem is solved. :thumbsup:
Return to “BETA TextMaker 2024 for Linux”
