Extension .docx and .bak in the text maker
kdb
Post by kdb »
After saving the file in the text maker, two files are formed. One with the extension .docx and the second .bak
Can someone explain why two files are created?
Thanks.
Re: Extension .docx and .bak in the text maker
Thanks for your post. Please check if you are using FreeOffice or SoftMaker Office 2021?
That file with .bak is the backup file.
kdb
Post by kdb »
Thanks for the answer.
