Activation code doesn't work
mbb
Post by mbb »
Hi!
The software installed with no issues. It was installed on my user directory. It launches, but when I enter the key supplied in the download email, I get a message saying there was an internal error and to try again or, in case it persists, to contact the support team.
My system is the following:
Code: Select all
System:
  Host: mbb-laptop Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 12.2.1 Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine:
  Type: Laptop System: Hewlett-Packard product: HP EliteBook Folio 9470m
    v: A1029D1102 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 18DF v: KBC Version 62.19
    serial: <superuser required> UEFI: Hewlett-Packard v: 68IBD Ver. F.73
    date: 04/12/2019
Maybe it matters That I have Softmaker Office 2021 permanently activated, installed system-wide. May this be the issue and do I have to uninstall it?
Tanks,
Smilodog
Re: Activation code doesn't work
Post by Smilodog »
Same problem here : persistent error message after entering product key :
An internal error (-105) occurred. Please try again later.
I'm also on Manjaro : could it be specific for Arch-based distros?
Thanks for reporting this problem. Our team have fixed it, please try to activate your Beta version now with the product key given in the email and share the results with us.
mbb
Post by mbb »
The problem persists. I even tried re-downloading and reinstalling.
Smilodog
Post by Smilodog »
Yes, I'm afraid that the problem is still here.
In a parallel thread people confirm successful installation on Endeavour OS, also Arch-based. So, I wonder, is it KDE-specific, or Manjaro-specific?
mbb
Post by mbb »
I just tried it on my desktop; same system but logged in LxQt+Openbox: same problem!
mbb
Post by mbb »
Installing system-wide "solves" the issue. I was able to unlock the software.
bemcl
Post by bemcl »
With the generic package "softmaker-office-nx-1107-amd64.tgz" I have the same problem.
With the DEB package it works fine.
Smilodog
Post by Smilodog »
Indeed, re-installing system-wide allows to launch Office.
Thank you, @mbb!
JohnbCallander
Post by JohnbCallander »
Wish I could get that far.
I am using Ubuntu on an older Surface pro and so need to install a deb64 version. I have tried to install as Deb as per the instructions. However, I am thinking because it is downloading to the download-folder I am not getting the syntax right.
Any one able to send me what I should be doing? If I can get this to work, it will make my old Surface Pro much more useful, including Presenter.
Thanks in advance. :)
John
Smilodog
Post by Smilodog »
I'm not on deb-based system now, so, I cannot check it myself. But if you open downloaded .deb package with GUI program, like GDebi (or similar), it should be installed without any syntax involved?
Smilodog
Post by Smilodog »
I just checked it on KDE Neon : downloading .deb package, and installing via Discover works fine.
JohnbCallander wrote: Thu Apr 13, 2023 12:27 pm Wish I could get that far.
John
raitis.veksejs
Post by raitis.veksejs »
The issue reported has been fixed and the fix will be delivered with the next update rev.1108.
Thank you for your contribution to make our SoftMaker Office better!
mbb
Post by mbb »
I confirm the issue is fixed. Installed the new build as regular user, on a different machine, and activated it using the same activation code which was supplied for the previous build.
