Still limitations on chart width in Planmaker
mart3383
Post by mart3383 »
Hi guys - the subject sums it up especially in this day and age with bigger, wider monitors.
Please would you consider introducing this feature/benefit in future builds
Re: Still limitations on chart width in Planmaker
Thanks for your post. Please share complete details of the problem with example file for better understanding.
mart3383
Post by mart3383 »
Nothing really to share but if you go into Object Properties (Chart) then the Max Width is restricted to 40.64cm. You cannot drag the side edge to increase.
I mentioned this in Planmaker 2021 and it was going to be passed to the Developers. I have no idea why this restriction is in place. Apologies for rubbing salt in the wound but other programs do not have this limitation - or at least the those I've tried.
raitis.veksejs
Post by raitis.veksejs »
I apologize that my colleague missed the fact that this problem has already been reported and our developers are working on it.
I reminded our team to check the status of solving this issue.
Return to “BETA PlanMaker 2024 for Windows”
