Installation successful
tlmiller
Post by tlmiller »
Just got it installed on my desktop (B450 board, 3700X) with no issues. No errors, and all 3 apps launch without issue. Debian 12 (bookworm).
Re: Installation successful
Thanks for the feedback.
tlmiller
Post by tlmiller »
Checked installation on an OpenSUSE Tumbleweed on my primary laptop (Lenovo T14s Gen3 AMD) install also, same thing. Installation proceeded without incident, and all applications worked after installation. I will also check on KDE Neon and EndeavourOS (Arch Linux) when time permits.
tlmiller
Post by tlmiller »
I have now also successfully tested on EndeavourOS (Arch linux) on a Lenovo ThinkPad T14 Gen2 AMD.
I did have to uninstall the prior Softmaker installation and manually clean up a few files in order to get it to work, or I'd get the same error as the other posters who are on Arch.
On a related note, If there's anyone who prefers AUR for the install over the install script that comes with the download, I have also created an updated AUR installer for the nx beta that works.
