Repository for BasicMaker Scripts
moneillqs
Post by moneillqs »
Does a repository for BasicMaker Scripts exist? It would be useful to not have to re-invent the wheel many times over.
Re: Repository for BasicMaker Scripts
Thanks for your post. There is no such repository because different requirements needs different code. So, please refer to the documentation and build the code as per your requirements.
There are few sample codes given in the SoftMaker/Sample folder which you can check.
