Why is admin privilege required?
patrick_
Post by patrick_ »
Why do Planmaker / Textmaker require admin privilege to be run? Those are the two programs I've tried, and -without providing any error- they don't start without being elevated. That's on Windows 10 x64.
Re: Why is admin privilege required?
Thanks for your post. There is no requirement of admin privilege to run the program. It seems some operating system level glitch.
Please reinstall entire program, rename Documents/SoftMaker folder and then check.
patrick_
Post by patrick_ »
Rename "C:\Program Files (x86)\SoftMaker FreeOffice 2021\" ?
Are you using SoftMaker Office 2021 or FreeOffice 2021?
Please rename Documents/SoftMaker folder after uninstallation of SoftMaker Office.
patrick_
Post by patrick_ »
raitis.veksejs
Post by raitis.veksejs »
After uninstallation you can try to remove folder C:\Program Files (x86)\SoftMaker FreeOffice 2021\ and rename folder ..Documents\SoftMaker
After that reinstall FreeOffice 2021.
