Permanently disabling auto hyphenation
Fudgemudge
Post by Fudgemudge »
I never want any documents I write to be hyphenated, so could you tell me how to permanently disable this feature please. In other words, I switch it off once and I never have to do it again each time I begin a new document.
I realise there is already a thread about this on the forum, but I am not authorised to access it for some reason.
Thank you.
Re: Permanently disabling auto hyphenation
Thanks for your post. To disable auto hyphenation from all the future documents also, please open your default template file which is by default Normal.tmvx, make necessary changes into it, save and close it.
After that, whenever you will create any new document with this template (which is default) you will get auto hyphenation disabled.
Post by Jossi »
Can you access this post? It's in the Mac forum, but it works the same way for the Windows version.
