Upgrade Major Version
Privacy4All
Post by Privacy4All »
I need to update my FreeOffice 2018 to FreeOffice 2021 on my Windows 10 PC. Do I simply download the 2021 version and install "on top" of the existing installation? Do I need to uninstall 2018 first? I don't want to blow anything up with an improper upgrade.
Thanks in advance for the reply.
Re: Upgrade Major Version
Thanks for your post. This will not upgrade the older office version, so if you don't want to use FreeOffice 2018, please uninstall it completely before installation of FreeOffice 2021.
