Using FreeOffice PlanMaker 2021 (rev F1062.0225) 32bit, On Windows 10 Pro build 21H2.
The ribbon "Insert" menu does not contain any option to insert a table. I selected the cells with data, went to the Insert menu, but the option to insert a table is gone. I just installed the patch to rev 1062, and the behavior is the same before and after. I have attached a screenshot showing the selected cells and the ribbon Insert menu.
I have an Excel spreadsheet with an existing table. Planmaker can see that table and properly displays the "table" tab. I just can't create a new table.
No way to create a table
- SoftMaker Office 2021
