Setting hyperlinks to files
saturn22
Post by saturn22 »
I want to create hyperlinks that link to graphic files. But I want the graphic files to always be (expected to be) in the same folder as my .doc or .pdf file. This is so I can give document and graphic files to anyone I want and they can run the document and see the graphics no matter what directory they put the files in on their local computer. How do I do this? Right now, it appears that the links always go into the current folder on my local computer. I want relative links, not exact links.
Thank you.
Re: Setting hyperlinks to files
Thanks for your post. Please click on ribbon command Insert | Hyperlink | Browse | select file | OK.
If you move the target file along with this TextMaker file having hyperlink, hyperlinks will also work without any problem.
