[SOLVED]Update error
General questions and answers about FreeOffice 2021 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
Mark_UK
Post by Mark_UK »
Hi, I followed the instructions to install FreeOffice into linux Mint at the following address..
https://www.freeoffice.com/en/service/t ... icks/linux
which are as follows...
sudo -i
wget -qO - https://shop.softmaker.com/repo/linux-repo-public.key | apt-key add -
echo "deb https://shop.softmaker.com/repo/apt stable non-free" > /etc/apt/sources.list.d/softmaker.list
apt update
apt install softmaker-freeoffice-2021
but later when update runs, it produces the following error...
W: https://shop.softmaker.com/repo/apt/dis ... /InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
Have the installation instructions changed but have not yet been updated in the Tips & Tricks section?
Many thanks
Linux Mint 21.1 Cinnamon
Hewlett-Packard OMEN i7-9750H 16GB Ram 500Gb SSD 1Tb sat3 HD
My idea of help from above is a sniper on the roof
Re: Update error
Thanks for reporting this problem. This is just a warning which you can ignore. I have forwarded the details to our developer team.
pete
Re: Update error
Post by pete »
The warning you are experiencing is due to changes in how apt stores the keys.
They are just warning and affects many other apt repositories.
They later versions of apt on linux mint stores the trusted gpg keys in the trusted.gpg.d directory, rather than in the /etc/apt/trusted.gpg file.
If you want to get rid of the warning safely, issue the following command if you get the warning after adding an apt repository:
Code: Select all
$ sudo cp /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d
As the trusted.gpg file is cumulative, you can safely issue the command every time you get the warning.
Mark_UK
Re: Update error
Post by Mark_UK »
Good to know, thank you.
SuperTech wrote: Mon Mar 06, 2023 12:51 pm Thanks for reporting this problem. This is just a warning which you can ignore. I have forwarded the details to our developer team.
Mark_UK
Re: Update error
Post by Mark_UK »
Hi Pete,
Thanks for your reply. I tried your suggestion, however it returns the following..
cp: cannot stat '/etc/apt/trusted.gpg': No such file or directory
Now that you guys have let me know I can ignore the messages, I will do just that.
pete wrote: Mon Mar 06, 2023 4:13 pm The warning you are experiencing is due to changes in how apt stores the keys.
Code: Select all
Return to “FreeOffice 2021 for Linux (General)”
