Hide Title border in presentations
smarty3010
Post by smarty3010 »
Hello,
How can I hide title borders which are visible in each slide? (Image is attached)
I tried to check for solution in File -> Options -> View. But I couldn't find any.
Thank you.
raitis.veksejs
Re: Hide Title border in presentations
Post by raitis.veksejs »
There exists an option to hide boundaries in dialogue File>Options>Show object boundaries but it is intended only for objects placed in slides manually, it doesn't work for presentation design placeholders.
Placeholder borders are necessary to see where empty placeholders are placed, without content and any border visible you can eventually lose them.
When you run the slideshow, these borders are not visible.
smarty3010
Thank you again raitis for your reply.
"Show object boundaries" is already unchecked.
I created a new slide in FreeOffice presentations 2021 having title and body (in an already existing presentation created from MS Office). Both title and body boundaries are visible in FreeOffice presentations 2021, whereas in MS Office Powerpoint 2019 the boundaries are not there. I am attaching both the images.
Can the boundaries be hidden in FreeOffice presentations 2021?
Thank you.
stascheit
Post by stascheit »
The boundaries for placeholders cannot be hidden in SoftMaker Presentations.
But when you start the slideshow for the audience, they are no longer visible.
Couldn't that be enough for your purposes?
smarty3010
This is not a big inconvenience, I can continue using FreeOffice Presentations 2021.
I would love to see a solution for this in future updates.
Thank you again.
Thanks for your understanding. We have already forwarded this improvement suggestion to our product management.
Return to “FreeOffice Presentations 2021 for Windows”
