Undo default save as option
smarty3010
Post by smarty3010 »
Hello,
First time, I selected "Save as" option in TextMaker I got two options: Microsoft formats or other formats (something like that).
Now, everytime I select "Save as" option in TextMaker, it directly opens Microsoft formats.
I want to have both the options: Microsoft formats or other formats everytime I select "Save as". Is there a way to do this?
Thank you.
raitis.veksejs
Re: Undo default save as option
Post by raitis.veksejs »
You should choose which file formats are most appropriate for you. If you wish to save in other formats, they are still available in file dialogue option Save as type:
You can also switch default file formats by selecting ribbon File command Options>Files and select Default file format:
