Show only one page and dont show margins
smarty3010
Post by smarty3010 »
Hello,
I have just installed FreeOffice.
In FreeOffice TextMaker:-
1. How can I show only one page at a time?
2. How do I disable page margins that are visible all the time?
3. In 2 column page, the column lines are visible -> How do I disable them?
Thank you.
raitis.veksejs
Re: Show only one page and dont show margins
Post by raitis.veksejs »
Here are answers to your request:
1. You can show one page by selecting the ribbon "View" command "Full page", for better readability you can use the command "Fit margins".
2. You can switch off mode to show margins as shown in the attached screenshot "Margins.png"
3. The same setting for margins also hides column lines.
smarty3010
Thank you for your quick reply.
The points 2 and 3 are resolved.
In the first point, I selected "Full page" from "View". The page view is too small that time.
After that:-
a) If I select "Fit margins" the page becomes much larger to view.
b) If I click on the "+" (zoom) button in the bottom right corner instead of "Fit margins" then I see multiple pages.
Is there a solution?
Thank you.
raitis.veksejs
You can disable the multipage view as shown in the next screenshot "Multi-page-view.png".
smarty3010
Thank you again.
The first point has been resolved.
