Automatic hyphenation are not turned off
Valentine
Post by Valentine »
Hello, everybody!
I found that automatic hyphenation are not disabled. In the Global settings (the "Language" tab) choose NOT to use automatic hyphenation.
But after rebooting or opening a new document, this option is active again.
Checked in TextMaker on iOS 16.3.1 and iPadOS 16.3.1.
Re: Automatic hyphenation are not turned off
Post by Jossi »
The global "automatic hyphenation" option applies in fact only to the present document. If hyphenation is on in every new document, it's probably an issue of your Normal.tmvx document template. Open it (it should be stored in On my iPad > TextMaker > SoftMaker > TextMaker 2021 templates > <Your language>), turn off automatic hyphenation and save it again.
Valentine
Post by Valentine »
Thank you very much for your help!
It works successfully!
:D
Return to “TextMaker 2021 for iOS”
