Hello, everybody!
I found that automatic hyphenation are not disabled. In the Global settings (the "Language" tab) choose NOT to use automatic hyphenation.
But after rebooting or opening a new document, this option is active again.
Checked in TextMaker 2021(Ubuntu 20.04 and derivative operating systems)
Automatic hyphenation are not turned off
Re: Automatic hyphenation are not turned off
Problem solved!
Instruction:
The global "automatic hyphenation" option applies in fact only to the present document. If hyphenation is on in every new document, it's probably an issue of your Normal.tmvx document template. Open it > SoftMaker/TextMaker 2021 templates/<Your language>, turn off automatic hyphenation and save it again.
Thanks to Jossi
Details: https://forum.softmaker.com/viewtopic.p ... 713#p74713
Instruction:
Thanks to Jossi
- SoftMaker Office 2021
- FreeOffice 2021
