changing the ruler to inches
woodworker will
Post by woodworker will »
I searched the various dialogues but couldn't find a way to change the rulers to inches instead of centimeters.
Can you help?
If it is unavailable could you add it to your list of requested items in the program?
stascheit
Re: changing the ruler to inches
Post by stascheit »
Use the command File | Options.
In the following dialog box, switch to the Editing tab.
On the top of this tab you will find the option Unit of measurement, here you can change the rulers unit.
Return to “FlexiPDF 2022”
