Column header selection
JacobD
Post by JacobD »
I'm trying to select the entirety of a single column. When I select column F, this works just fine, but when I try to select column AV, the sheet will scroll to the left until it reaches the beginning of the sheet. I used F and AV as examples; the dividing line is X. Anything to the left of column X won't scroll, anything to the right will.
Is there a setting that I need to change, or should I submit a bug report if possible?
raitis.veksejs
Re: Column header selection
Post by raitis.veksejs »
Hello, JacobD
we would be grateful if you could send us a more detailed description step-by-step what you do until the problem occurs, also provide the SoftMaker Office file sminfo.txt and a sample document to forum@softmaker.com
Thank you in advance!
