Set password on a document
stefanmaine
Post by stefanmaine »
TextMaker Professional 2021 on MacOS Ventura 13.1
Is there a way to password protect a single document prepared in TextMaker?
Thank you.
Re: Set password on a document
Thanks for your post. Yes, click on ribbon command File | group File management | Properties | Protection tab, under document protection select the appropriate option and set your password, click OK.
