Layout in classic view
utc0
Post by utc0 »
I can't find a "Layout" tab or something related in classic view, while it appears in ribbon mode. For example, I can't change page margins which is very important for my current document. I work on small laptop and classic view with big icons is convenient. Please tell me where I can change page margins.
Re: Layout in classic view
Post by Jossi »
Go to Tools > Customize and type "page" into the "Quick search" field. You may either choose "Page margins" or "Page setup" and draw the icon into the icon bar, whichever suits you better. I prefer "Page setup" as it has all the options in one dialog box.
beenthere216
Post by beenthere216 »
Jossi wrote: Thu Feb 02, 2023 6:28 pm Go to Tools > Customize and type "page" into the "Quick search" field. You may either choose "Page margins" or "Page setup" and draw the icon into the icon bar, whichever suits you better. I prefer "Page setup" as it has all the options in one dialog box.
I'm late, but I just noticed this. The way to access margin (and other) settings in the Classic menu is File > Page Setup > Page Format
