Open TM to Last Document Edited?
Jake
Post by Jake »
Given the curved screen of my phone, it's sometimes hard to click File, then go to Recently Used Documents.
Is there a command/setting to open TM that also opens the last document edited?
Thanks,
Jake
Re: Open TM to Last Document Edited?
Thanks for posting your problem. Yes, you can use quick launch bar and menu also as shown in the below screenshot.
Recent documents.jpg (15.22 KiB) Viewed 32286 times
