Adding money in cells in the same row
pussycat
Post by pussycat »
I have a spreadsheet using 32 rows and 4 columns. All cells show a monetary value in Pounds. Columns A,B and C record my investment accounts and column D show the sum of columns A,B and C. Using the formula =SUM(A1,A2,A3) the correct addition is shown in column D for all 32 rows except three which shows only the amount of money in column A. I have double checked that the correct formula is entered in column D in the cells which are not showing the correct addition and I can't understand why the correct calculation is not made.
Re: Adding money in cells in the same row
Thanks for posting your problem. Please share the file in which you are getting this problem so that we can check it.
