Range names in Office2021
stefanob
Post by stefanob »
Hello,
just installed SoftMaker Office2021.
Used to use libreoffice calc, but I have some issues with formulas containing range names. Saving files in xlsx format and sharing them with excel users, sometimes I loose range names, so formulas in the cells give back #NAME instead of the result.
I wanted to ask if PlanMaker would have this kind of problem, or others, when sharing editing of xlsx files (PlanMaker 2021 on linux and Excel, not sure about the versionof the latter).
Best regards
Stefano
Re: Range names in Office2021
Thanks for sharing your problem. Please share any sample file before saving in Excel in which you are getting this problem so that we can test it at our end.
Return to “FreeOffice PlanMaker 2021 for Linux”
