When I paste into Textmaker a text from a website, an unexpected page break frequently occurs in some portion of the text.
A partial solution I use is to apply "normal" from the Paragraph Style, but it destroys the formatting of the subsequent headers in the text.
Another way ?
unexpected page break on copied text
- EB 16jan2023 - Indépendant quelle déductibilité fiscale voiture.docx
- (15.97 KiB) Downloaded 4863 times
Re: unexpected page break on copied text
Thanks for reporting this problem. Please let us know the URL of the webpage from which you are pasting, the browser you are using for this purpose and share a screenshot of the "unexpected page break" so that we can check this issue at our end.
Thanks for your reply !
Under Windows10, I use Firefox, but the problem arises also with Chrome.
I cannot give you the url of the newspaper page, because it requires a paid subscription. But the problem come also with plenty other sites.
For example, on a free access site :
http://www.droitbelge.be/fiches_detail. ... =32&id=834
Here, the pasting of the copied page into TextMaker produce :
on the 1st page : the title "Livre V .... SRL"
on another page : the start of the text with "Les règles régissant ...."
No matter if site is an http:/ or an https:/
Best regards,
Best regards,
And here is a screen shot of the 1st page in TextMaker
- Contact:
Many of the paragraphs have the flag "Keep together" set which forces TextMaker to format them the way it does. Select the whole text and remove the flag.
