Documents freeze when opening
pavplus57
Post by pavplus57 »
Newly created and existing documents freeze and display a completely blank document when opening the first time. I have to force close the document and reopen it. This occurs every time I open a document. I'm running a laptop with Windows 10. I don't have any similar errors with other programs.
Re: Documents freeze when opening
Thanks for posting your problem. Please check a few things:
1. Please update your SoftMaker Office to the latest revision.
2. If your antivirus/security software blocking the app.
3. Your Windows and display driver are updated or not.
pavplus57
Post by pavplus57 »
Hello. Thanks for your reply.
I'm running the 2018 Anniversary edition and it shows no updates are available. I'm thinking about uninstalling and starting fresh with the 2021 edition but I would have to pay for that, of course. I could try the free trial for 30 days to see how it works.
My security software shows that no apps have been blocked.
My drivers are up to date.
I tried opening the program from the Start menu as Administrator and it still hung on the first try.
Any other thoughts before I try a completely new install?
pavplus57 wrote: Mon Jan 09, 2023 5:55 pm I'm thinking about uninstalling and starting fresh with the 2021 edition but I would have to pay for that, of course. I could try the free trial for 30 days to see how it works.
You can install SoftMaker Office 2021 for trial use without uninstallation of SoftMaker Office 2018.
