App for ARM Processors?
Post here those questions, bug reports and suggestions for SoftMaker Office 2021 for Android that do not fit in any of the application-specific subforums.
embryo
Post by embryo »
Good morning from the Philippines.
Recently had a Chromebook, unfortunately it is managed, and I cannot use Linux.
I, however, can install under Android. When I install PlanMaker, there is a warning, "This app has been created for ARM processors. Your Android device does not use such a processor. The application will not quit."
Can I use the SoftMaker Android products under ChromeOS? Tried the HD version (which I have a license), but it does not show under Google Play, and I can't install the app offline.
Re: App for ARM Processors?
Thanks for your post, but Chrome OS is not a supported operating system. You can follow our article How to run SoftMaker Office on a Chromebook.
embryo
Post by embryo »
Thanks for the link, but the chromebook I have is managed, thus I can't turn on developer mode and Linux, so I can't install the Linux version of Softmaker. It is weird that the app said that it is for ARM only, and not that the OS is unsupported.
Return to “SoftMaker Office 2021 for Android (General)”
