Download size
Dimps999
Download size
Post by Dimps999 »
What is the size of the FreePDF 2022 download? I seem to remember when I downloaded a version in 2021 it was HUGE! I do not have a huge hard disk!
Re: Download size
Thanks for your post. File size of FreePDF 2022 setup is 202.09 MB.
Dimps999
Re: Download size
Post by Dimps999 »
Thanks! I should have asked at the same time ... how much space does the program take when it is unpacked/installed?
Re: Download size
It's completely free software, please install and check. :thumbsup:
Dimps999
Re: Download size
Post by Dimps999 »
I just tried to download the software on Win11 but received the message "Website blocked due to suspicious content"!!
Maybe the download size is not the most important factor!
UPDATE: The message was from Malwarebytes {Download blocked: http://eshop.getfreepdf.com/customer/re ... -confirmed. Malwarebytes Browser Guard scans downloads started in the browser and may block/remove the item if it looks suspicious. If you trust this content/site and would like to proceed, click "Continue".]
Perhaps foolishly I decided to continue, but wish I hadn't bothered, as the download [Unconfirmed 570658.crdownload] got to 194MB then stopped after an hour or so.
Re: Download size
Please check your internet connection, internet speed and you can try any different browser also.
Re: Download size
I just downloaded it. The file size is 206,949 kb. The download only took a few minutes.
Dimps999
Re: Download size
Post by Dimps999 »
Thanks SuperTech and Woody44 ... my internet connection is very slow here (SE Asia), so I will try again sometime when I think the connection might be better! Thanks for your comments.
Dimps999
Re: Download size
Post by Dimps999 »
I finally got to complete the FreePDF download (206MB) which was 295MB when unpacked/installed.
Yay!!
Return to “FreePDF 2022”
