ascii character for Textmaker column break
DJungk
Post by DJungk »
Hi,
I'm trying to paste text into a Textmaker doc which has styles already set. I am creating the text files with another program that I control. Is there a character that I can put in that will make a column break in the Textmaker page?
I tried copying out text from Textmaker with a column break, but it is copied as a paragraph break (i.e. ascii 10 on LInux)
Thank you,
Don
Re: ascii character for Textmaker column break
Thanks for your post, but there is no such character or ASCII code available for column break.
