Unseen picture and Some suggestion
Buger
Post by Buger »
It is ok on Powerpoint(desktop version)
but can not display on Presentations
And Objects are not on correct place
file:
test.pptx
(49.09 KiB) Downloaded 5559 times
Suggestion:
Add 'only' pen support
Finally, app is very well and fluency =D>
Re: Unseen picture and Some suggestion
Thanks for posting your problem with sample file and screenshot. These are OLE objects and EMF format image, which are currently not supported in Presentations 2021 for Android.
Return to “Presentations 2021 for Android”
