creating tables of a given width
mauricebis
Post by mauricebis »
I upgraded from 2018 to the 2021 version of Textmaker on Linux. I was really expecting I could create tables from a given width in pts or %, since this option is not available in 2018 version, and this was my reason for upgrading. Unfortunately, I can't see anyway of doing this at the table level (not the cell level), the width is not listed as a table property while this is fundamental. This is very annoying since I want all my tables being centered and being 90% width of the page. Well, money wasted...
Re: creating tables of a given width
Thanks for your post. Currently, this option is not available, but I have forwarded this as an improvement suggestion to our product management.
mauricebis
Thanks. I think this would help lots of your users. It's even available in CSS when designing web pages, it's a fundamental tool. Hope I could upgrade soon.
Post by Jossi »
As a workaround, you could put the tables in a text box with given width.
raitis.veksejs
Post by raitis.veksejs »
Another workaround (without using textbox) can be seen in the attached screen recording.
mauricebis
Jossi wrote: Wed Mar 22, 2023 10:33 am As a workaround, you could put the tables in a text box with given width.
Sure the textframe can be centered but the width can't be defined as a percentage to anticipate for possible margin changes.
mauricebis
Hello, tried the 2024 version, still the basic option of defining the width of a table in pts and % not available.
Yes, I have forwarded this feature idea again, but you can define the same after building table using cell properties as shown in the below screen recording:
Just remember to select the entire table and divide the desired table width with number of columns, e.g., if you want 5 columns table of 50% or 5 inch or cm, define cell value 10% or 1 inch or cm.
