BeckerCAD14 3D Pro for Windows - Update & Miscelaneous Questions
RKanarek
Post by RKanarek »
Greetings,
Regarding the new (as of Thursday, October 27, 2022) version of BeckerCAD (BeckerCAD14 3D Pro for Windows) that is being marketed to existing SoftMaker and/or SoftMaker BeckerCAD users:
a. Must one or should one REMOVE the previous (Softmaker) version BeckerCAD (BeckerCAD12 3D Pro) before installing the new version of BeckerCAD?
b. Must one or should one INSTALL the previous (Softmaker) version BeckerCAD (BeckerCAD12 3D Pro) before installing the new version of BeckerCAD?
c. Previously SoftMaker supplied a link from which one could obtain an English language version of the BeckerCAD12 3D user's manual (https://www.softmaker.net/down/2020/bec ... pro_en.pdf, which still works). Is there a new English version of the manual, and if so how does one obtain it?
d. The publisher describes the system requirements for BeckerCAD14 3D Pro as follows:
Betriebssystem Windows Windows 11, 10, 8.1, 8
(From https://www-mut-debeckercad/beckercad-1 ... em.require)
Does it really not run properly under Windoze 7 x64?
Kind regards,
Richard Kanarek
Re: BeckerCAD14 3D Pro for Windows - Update & Miscelaneous Questions
Thanks for your post. Please refer to the manufacturer's website for complete details of the product BeckerCAD: https://www.mut.de/beckercad.html
You can also contact their support team using their Contact us link.
Return to “Water Cooler”
