XLS not parsing well
noname
Post by noname »
I generated an XLS file from a database, but it seems that PlanMaker (running it on Windows 10) has issues parsing the data in the correct cells for some weird reason. Sometimes it works well but when he finds "something" he does not like, he just merges the cells. The thing is that I have opened the same XLS file in https://products.aspose.app/cells/viewer and there everything is in its own correct cell.
If you guys can reproduce the same issue based on the file I have attached please investigate and fix this. Thanks!
itemdata-20-10-2022invoice_usd.xls
(883 Bytes) Downloaded 5212 times
Re: XLS not parsing well
That is not an excel file. It's a Tab-Separated Values TXT file. Please rename its extension from XLS to CSV and you'll be able to import it into PlanMaker successfully.
