Create envelopes
davemngl@gmail.com
Create envelopes
Post by davemngl@gmail.com »
The manual says to go to Mailings|Group Create|Envelope. I can't find group Create! Please help!
stascheit
Re: Create envelopes
Post by stascheit »
If you use the ribbon interface, see screenshot below for Mailings | command group Create | Envelope.
If you use the classic menu interface, choose the command Insert > Envelope.
