Search and Replace
AlanB
Search and Replace
Post by AlanB »
New to BasicMaker and need to know if it is possible to use a script for a search and replace task. Can't see anything in the manual or online.
Need to automate the task of searching for numbers in a certain paragraph style and concerting those numbers to superscript. Easy enough using TextMaker's Search and Replace, but as I do this all the time, it would be good to have a script to automate the task.
Re: Search and Replace
Thanks for posting your query but currently it's not possible. I have forwarded this improvement suggestion to our product management.
