Zotero references, moving docs PC -> Android -> PC
leadermontanus
Post by leadermontanus »
Hi,
I'm currently using Textmaker for Android (paid version) and I am looking into upgrading to the NX version. If I have this version will Zotero field codes be preserved when moving a document from Linux PC to Android and back to Linux PC? I intend to edit both on PC and Android, but only insert Zotero references on PC.
The reason I ask is that when I moved a document from Microsoft Word to Textmaker on Android and back, then all the Zotero references (which were stored as bookmarks so they should be portable) were lost.
Thanks for the help!
Re: Zotero references, moving docs PC -> Android -> PC
Thanks for reporting this problem. Please share any sample file containing the Zotero reference that is creating this problem for you.
