Expressions like page number { Nr.} in the footer
enginpost
Post by enginpost »
I am completely new to the tool. I love that you can use an expression in the footer to print the current slide number, like...
Code: Select all
{ Nr. }
This handles the use-case where people are looking at a PDF or a print-out of slides and want to jump to a specific slide on a page.
The use-case I want to handle is...
As a presentation viewer, I need to understand how far through the presentation I am, so I can pace my learning.
A possible implementation of this would be the ability to add a total number of slides into the foot as well, like...
Code: Select all
Slide { Nr. } of { Total }
or
Code: Select all
 { Nr. } / { Total }
Can this be done? Where can I learn more about the available expressions that can be included in the Master Page areas?
Re: Expressions like page number { Nr.} in the footer
Thanks for your post. Customized expressions are not currently available. After activation of the master slide, please click on the ribbon command Insert | Header/Footer and you will able to find the available options there.
Return to “Presentations 2021 for Windows”
