whitescreen on load i give up
General questions and answers about FreeOffice 2021 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
freeoffcusr
Post by freeoffcusr »
intel j1900 celeron
w/
4gb ram
intel integrated graphics
tried installing on latest build of fydeos
tried installing on latest build of chrome os flex
both were freshly installed with no modifications or changes beyond default install (added linux environment to both)
downloaded
installed freeoffice 21 linux w/ no errors completed successfully
all freeoffice apps populated the apps menu upon completed insstallation
loaded each app
each app loaded with a white screen and blinking cursor
could not see anything
current os theme is 'light'
Re: whitescreen on load i give up
Thanks for posting your problem but the Linux distributions you mentioned are not supported.
Please check and use one of the supported Linux distributions listed on this link: FreeOffice 2021 for Linux
Return to “FreeOffice 2021 for Linux (General)”
