TEXT CORRECTION
parascebe@gmail.com
TEXT CORRECTION
Post by parascebe@gmail.com »
Good morning. I am thinking of purchasing this program for use in my work. Word processors are essential for me. But I need to know if the proofreading tool, when activated, indicates the changes or correction if it puts it in another color, and if the changes are indicated in the margin in a side column if the comments are visible in that same column. Thank you very much.
Re: TEXT CORRECTION
Thanks for your post.
Yes, when you will enable the "Track changes" option from the ribbon command Review | Changes, it will show the changes in different colors. You can check all the details related to changes like the user who did that with a timestamp when you hover your mouse on those changes. All comments will be shown on the right side of the page.
We are providing 30 days trial period so if you want before purchasing you can use and check the features by yourself also.
As this is an English-only forum, please post in English language only. I have updated your post with the translation.
