!!UPDATED!! Making a chart using multiple columns-area
maestro2022
Post by maestro2022 »
Hello to everybody...
Trying to make a chart using an area from a1 to a11 (a1:a11) and c1 to c11 (c1:c11).
I select the first area and by pressing the CTRL key I select the second area.
Tried to make a "column chart".
The result wasn't what I expected, It doesnt make it (it doesn't keep the selected areas).
Can you give an idea or help...
Thank you.
Re: !!UPDATED!! Making a chart using multiple columns-area
Thanks for your post, but currently this feature is not available. I have forwarded this improvement suggestion to our product management.
