Problem separator export csv
Mial
Post by Mial »
I use a lot of csv files and this application seems to me the best ! However I have a major bug I can't change the column separator on the csv export to "save as". I have the popup please wait, I see stealthily options and then it remains on "tabulations" ...... ??!
Re: Problem separator export csv
Thanks for your post. Please share your CSV file in which you are getting this problem with a screenshot of the issue so that we can check it at our end.
Return to “PlanMaker 2021 for Android”
