Licensing issue
EricC
Licensing issue
Post by EricC »
Hi SoftMaker team,
I have had had a licensing issue since June 28th and the issue is still not resolved. I received my last response to this issue on July 12th. Since then I have emailed several times with no response. I am sending an email to the forum address hoping someone can address this issue. This issue is the first time I have ever been annoyed with regards to support.
Re: Licensing issue
Sorry. I have now fixed this and can only apologize. This was not handled well at all.
EricC
Re: Licensing issue
Post by EricC »
Thank you Martin. I am now having an issue of SMO not liking my license key (same one I used previously on the machine). Don't know if the activation count needs to be reset?
Re: Licensing issue
I have looked at both keys and they are fine. I cannot see any attempt to use the 53... key. What is the error message?
EricC
Re: Licensing issue
Post by EricC »
Hi Martin,
The 53 key is what I use for my work machine and is fine. It's the 17 key that I use for home that is still not working.
When I launch TM on my home machine, I get the prompt that my subscription has expired (In the past if the subscription expired and was then renewed TM would launch fine). I decided to give the Change Product Key option a try. It showed the 17 key. Even after I clicked OK, I am still told my subscription has expired.
-Eric
Re: Licensing issue
I found the problem and fixed it.
EricC
Re: Licensing issue
Post by EricC »
Everything is working now. Thank you for your help!
fcibok
Re: Licensing issue
Post by fcibok »
I wm havia the same issue. Cannot registrou due tô internet or vírus. Please help!
Re: Licensing issue
If you are unable to register due to the internet or virus-related problem on your computer. Please solve these problems and then you will able to register.
For internet-related problems, you can call your internet service provider, and for viruses, scan your computer with any good antivirus to check if your computer is infected.
Abdlah
Re: Licensing issue
Post by Abdlah »
How was this matter resolved? Because I have tried re-installing Softmaker 2021 that I have an update license for, but I keep being told the beta version has expired and to visit softmaker.com for an updated version.
Re: Licensing issue
Abdlah, your post is unrelated to what is discussed above. Your problem is that you participate in the beta and your beta has expired. If you are on Windows, running ? | Check for updates should install a service pack with the latest beta which expires on June 30.
