Invoking Plan Maker Formulae From Basic Maker
Mennochio
Post by Mennochio »
How do I invoke formulae from Plan Maker in Basic Maker code?
For example, "=DECIMALS(1.235)" in a cell of Plan Maker yields 0.235.
But n =DECIMALS(1.235) in Basic Maker results in "Sub or function not defined: DECIMALS"
Thanks.
Re: Invoking Plan Maker Formulae From Basic Maker
Thanks for posting your problem. You can use Formula property of object range or cells in this case.
Code: Select all
pm.Range("a2").formula="=DECIMALS(1.235)"
OR
Code: Select all
pm.cells(2,1).formula="=DECIMALS(1.235)"
You can refer to our user manual for complete details here.
Mennochio
Post by Mennochio »
Thanks. :D
