Auto Word wrapping to next line
thebrituk
Post by thebrituk »
Is there a way to enable word wrapping to the next line as default. TextMaker has the habit of inserting a hyphen (-) thus splitting the word between the lines. Both on Mac and ISO. This makes TextMaker less productive as you have to spend time correcting your document.
Re: Auto Word wrapping to next line
Post by Jossi »
In ribbon interface, go to Layout > Paragraph and click "Hyphenation". There you can deselect hyphenation for the current paragraph or the whole document. In classic interface, it's Tools > Automatic hyphenation for the current document or Format > Paragraph for the current paragraph.
If you want all your documents without hyphenation in the future, go to the "Open" dialog and choose "Templates (*.tmvx, *.tmv)" as File type. Then choose your default document template (in most cases, this will be "Normal.tmvx"), deselect hyphenation for the whole document and save the template.
thebrituk
Post by thebrituk »
