Show/hide zeroes
Bampah
Show/hide zeroes
Post by Bampah »
According to the help section, I should be able to go to View>Show Zero to show/hide zeroes.
I can't find this command in the drop down box.
What am I missing please
tia Rob
Re: Show/hide zeroes
Thanks for your post. This option is in sheet's properties, which you can access by clicking on ribbon command Insert | group Tables | Sheet dropdown| Properties.
Or you can access this by right click on sheet's name and then select properties.
stascheit
Post by stascheit »
@ Bampah
The help section you describe, refers to the Ribbon UI.
If you use the user interface with the Classic menus, choose the menu command Worksheet > Worksheet > Properties.
