Can I make TextMaker remember the last directory I saved in?
silph
Post by silph »
If I close TextMaker, and then open TextMaker again and create a New document, and then try to save it, the directory that TextMaker shows to save the document is always "Device Memory ( /storage/emulated/0 ) . I'd like TextMaker to instead remember the last directory I saved in. Is this possible?
Re: Can I make TextMaker remember the last directory I saved in?
Thanks for posting your problem. Please share a screenshot of the problem for better understanding.
